Quit
Ends BricsCAD; optionally saves unsaved drawings.
command bar:  quit
shortcuts:  Ctrl+Alt+Q, Alt+F4
alias:  exit
menu bar:  File | Exit
: quit
If no drawings need to be saved, exits without displaying any dialog boxes or prompts in the command bar.
If drawings are unsaved, displays a dialog box:
Yes
Saves the drawing, and then exits BricsCAD.
No
Does not save the drawing, and then exits BricsCAD.
Cancel
Cancels the command; BricsCAD does not exit.
Open - opens drawing files.
Close - closes the current drawing.
WClose - closes the current window.
