Open
Opens drawing (DWG), template (DWT), and interchange (DXF) files.
command bar:  open
shortcut:  Ctrl+O
aliases:  op, im, import
menu bar:  File | Open
toolbar:  Standard |
: open
Choose a file, and then click Open.
Look in
Selects the drive and folder.
File name
Specifies the name of the file.
Files of type
Selects the type of file:
  • DWG - BricsCAD drawing file
  • DWT - template file
  • DXF - interchange file
Open
Opens the file.
Cancel
Closes the dialog box without opening a file.
Open as read-only
Opens the drawing in read-only mode. The drawing cannot be saved to the same file name.
Use Preview
Displays the preview image of the drawing.
Close - closes the current drawing.
Quit - exits BricsCAD after closing open drawings.
New - starts new drawings.
SecurityOptions - sets a password to protect a drawing
WorkSets - creates and loads a set of drawing files. Allows to work with a named group of drawings.
