Rotate
Rotates entities in 2D.
command bar:  rotate
alias:  ro
menu bar:  Modify | 2D Rotate
toolbar:  Modify |
: rotate
Select entities: (Select one or more entities.)
Entities in set: 1
Select entities: (Select more entities, or press Enter to continue.)
Rotation point: (Pick a point or enter x,y coordinates.)
Copy/Base angle/<Rotation angle>: (Enter an angle, or type C or B.)
Select entities
Chooses the entities to be rotated.
You can choose one or more entities using any entity selection method.
Press Enter to end entity selection.
Rotation point
Specifies the point about which the entities will rotate.
Pick a point, or enter x,y coordinates.
Use entity snaps for an accurate rotation point.
Rotation angle
Specifies the angle by which to rotate the entities:
  • Enter a point to show the angle.
  • Enter a positive or negative number to specify the angle.
Positive numbers rotate entities counterclockwise from the positive x axis.
Copy
Creates a rotated copy of the selection set.
Base angle
Specifies the a new base angle; prompts you:
Base angle - specifies the base angle.
New angle - specifies the angle by which to rotate the entities.
This command normally rotates entities relative to the positive x axis.
This option lets you define a different angle as the starting point.
Procedures
Rotating a selection set
Rotating a selection set in reference to a base angle
To rotate entities using grips
To rotate the display in a viewport
Rotate3D - rotates entities about axes in 3D space.
Align - aligns one entity with another.
Snap - rotates the cursor, ortho angle, and grid.
UCS - rotates the coordinate system.
