Sketch
Creates freehand sketches.
command bar:  sketch
alias:  freehand
menu bar:  Draw | Sketch
toolbar:  Draw |
: sketch
Sketch:  Length of segments <0.1000>:  (Enter a number, identify two points or press Enter to accept the default.)
 Press ENTER or click to toggle Pen/Quit without save/Record (save)/Erase/Connect/Straight/eXit with save:
Click to start sketching, click again to toggle pen up/down.
Enter an option, or press X followed by Enter to exit command.
During sketching, the lines are green until the sketch lines are saved:
Saving sketch lines ...
Depending of the status of the SKPOLY system variable sketches are made from lines or polylines.
Length of segments
Specifies the length of segments.
Enter a number.
Too small a segment length results in large drawings.
Toggle Pen
Allows you to move the pen without drawing.
Quit
 Exits the command without saving the sketch.
Record
Saves the sketch; reports:
Saving sketch lines.
Continue sketching.
Erase
Erases the sketch lines from their endpoints interactively. Click to stop erasing and restart sketching.
Connect
Connects cursor to end of the last segment; prompts you:
Point cursor to end of last sketch line - move the cursor to the end of the last sketch.
This option is meant for use after a pen up.
Straight
This option works only when the pen is  up.
Draws a straight segment to the current cursor location .
Exit with save
Exits the sketch command.
Procedures
Setting the Sketch Poly (SKPOLY) system variable
Creating a freehand sketch
PLine - draws polyline segments and arcs.
RevCloud - draws revision clouds.
