Stretch
Stretches entities.
command bar:  stretch
alias:  s
menu bar:  Modify | Stretch
toolbar:  Modify |
: stretch
Select entities to stretch by crossing-window or crossing-polygon: (Pick a point, or enter C or CP.)
Opposite Corner: (Pick another point.)
This command works only with crossing selection modes.
Entities in set: 1
Select entities to stretch by crossing-window or crossing-polygon: (Choose more entities, or press Enter to continue.)
Base point of displacement: (Pick a point, or enter x,y coordinates.)
Second point of displacement: (Pick another point.)
Text cannot be stretched.
Selects the entities to stretch; must use Crossing or Crossing Polygon mode:
  • C - crossing mode.
  • CP - crossing polygon mode.
When using the cursor, pick the second point to the left of the first:
Crossing mode is indicated by a dashed selection rectangle.
The selection rectangle (or polygon) determines how this command affects entities:
  • Entities crossing the selection rectangle are stretched.
  • Entities within the rectangle are moved.
  • Entities outside the rectangle remain in place.
Specifies the starting point of the stretch.
Specifies the stretch distance by the distance between two points, base and second point.
Procedures
To stretch entities
To stretch entities using grips
Lengthen - changes the length of open entities.
Extend - extends open entities.
Scale - changes the size of entities.
Properties - changes the geometry of entities.
