Properties
Displays the Properties palette with properties of selected entities.
command bar:  properties
aliases:  ch, pr, props, mo, ddchprop, ddmodify
menu bar:  Modify | Properties
toolbar:  Standard |
: properties
Displays a palette with varying content:
Options
Reports the number of selected entities.
Click to see the number of each entity type in the current selection set:
Select an entity type in the list to see the shared properties of all entities of this type in the current selection set.
Quick Select
Switches between Properties and Quick Select mode (See also the Qselect command).
General
Color
Reports the current color.
Allows to change the color of selected entities:
  1. Click the droplist and then choose another color.
  2. Choose Select Color to access the Colors dialog box.
 See Color command.
Layer
Reports the current layer name. To change the layer of selected entities:
  1. Click the droplist, and then choose another name.
See Layer command.
Linetype
Reports the current linetype. To change the linetype of selected entities:
1. Click the droplist. and then choose another name.
2. Choose Load to access the Load Linetypes dialog box.
See Linetype command.
Linetype Scale
Reports the current linetype scale factor.
To change the linetype scale, enter a new value. See LTSCALE system variable,
Plot Style
Reports the current plot style. To change the plot style of selected entities:
  1. Click the droplist and then choose another name.
(This property is available only when plot styles are enabled for the drawing. See PlotStyle command.)
Lineweight
Reports the current lineweight. To change the lineweight of selected entities:
  1. Click the droplist and then choose another width.
See LWeight command.
Hyperlink
Reports the current hyperlink. To change the hyperlink of selected entities:
1. Enter a new URL.
2. Click the button to access the Edit Hyperlinks dialog box.
See Hyperlink command.
Thickness
Reports the current entity thickness. To change the thickness of selected entities:
  1. Enter a new value.
See Elev command.
Material
Reports the current Material definition of the selected entity.
To change, click the settings field, then select a material from the drop-down list.
See the Materials command to manage material definitions.
View
Camera / Target
Reports the current position of the Camera and Target properties of the view.
See the Camera command.
Perspective
Reports the current value of the PERSPECTIVE system variable.
Allows to switch the perspective view mode on/off.
Lens Length
Reports the current value of the LENSLENGTH system variable.
Allows to edit the value of the LENSLENGTH system variable.
Field of view
Reports the current view angle.
Allows to edit the camera view angle. Editing this value affects the value of the LENSLENGTH system variable.
Height / Width
Reports the dimensions of the current view in drawing units.
Visual Style
Reports the current visual style.
Allows to select a different visual style.
See the VisualStyles command.
Misc (Miscellaneous)
Annotation Scale
Reports the current value of the CANNOSCALE system variable.
Allows to edit the value of the CANNOSCALE system variable.
All scales defined in the drawing are available (see the ScaleListEdit and -ScaleListEdit commands)
Other properties vary, depending on the entity selected.
Area - reports the area, circumference, and perimeter of entities.
AttEdit - edits attribute values and properties.
AttRedef - redefines a block and updates associated attributes.
AttSync - synchronizes attribute definitions in all block references of a specified block definition.
BattMan - manages the attributes of a block definition.
Dist - reports the 2D and 3D distances between two points.
EAttEdit - edits attribute values and most properties.
Id - reports the x,y,z coordinates of picked points.
Layer - assigns properties to layers.
List - lists the area and other parameters of entities in the command bar.
MassProp - reports the properties of solid models and regions.
PlotStyle - sets the current plot style.
