Tolerance
Places tolerance symbols in drawings.
command bar:  tolerance
alias:  tol
menu bar:  Dimensions | Tolerance
toolbar:  Dimensions |
: tolerance
Select tolerance symbols and enter values, and then click OK.
Select location for tolerance: (Specifies the insertion point for the tolerance symbol.)
Geometric tolerance symbols
Symbol
Characteristic
Type
Position
Location
Concentricity or Coaxiality
Location
Symmetry
Location
Parallelism
Orientation
Perpendicularity
Orientation
Angularity
Orientation
Cylindricity
Form
Flatness
Form
Circularity or Roundness
Form
Straightness
Form
Profile of a surface
Profile
Profile of a line
Profile
Circular Run-out
Run-out
Total Run-out
Run-out
Material conditions
Symbol
Definition
At maximum material condition (MMC), a feature contains the maximum amount of material stated in the limits.
At least material condition (LMC), a feature contains the minimum amount of material stated in the limits.
Regardless of feature size (RFS) indicates that the feature can be any size within the stated limits.
Symbol
Inserts a tolerance symbol; displays dialog box:
Choose a symbol, and then click OK.
Tolerance 1
Tolerance 2
Specifies tolerance specification:
Diameter - toggles the diameter symbol when clicked.
Value - specifies the tolerance value.
Material condition - displays dialog box when clicked:
Datum 1
Datum 2
Datum 3
Specifies the datum reference:
Value - specifies the datum value.
Material condition - click to display the Material Condition dialog box.
Height
Specifies the height of the tolerance symbols.
Datum Identifier
Specifies datum indentifier, such as Datum A.
Projected Tolerance Zone
Toggles the projected tolerance zone symbol:
Procedures
To create a geometrical tolerance frame
Grips Editing
Tolerances can be edited directly through grips:
  1. Select the tolerance. Notice that it has one grip.
  2. Drag the grip to move the tolerance.
Leader - attaches tolerances to leader lines.
DimOrdinate - draws x and y ordinate dimensions.
