DimOrdinate
Measures x and y ordinate distances from a common point at the current UCS origin.
command bar:  dimordinate
aliases:  dor, dimord
menu bar:  Dimension | Ordinate
toolbar:  Dimensions |
: dimordinate
Select point for ordinate dimension: (Choose a geometric feature.)
Text/X datum/Y datum/Angle/<Leader endpoint>: (Pick an endpoint for the leader, or enter an option.)
Dimension text = \A1;6.2386
Chooses the start point of the ordinate leader; usually is a geometric feature, such as a corner or circle.
X datum
Forces the ordinate dimension to measure the x distance; the distance is measured from the origin of the current UCS.
Move the UCS, if required.
Y datum
Forces the ordinate dimension to measure the y distance.
Angle
Specifies the angle of the text; useful for keeping text horizontal with inclined dimension lines. Prompts you:
Angle of dimension text - specify the rotation angle of the text.
Text
Specifies the text; useful for overriding the default measurement generated by BricsCAD. Prompts you:
Dimension text - specify the replacement text.
Leader endpoint
Specifies the end point of the leader.
Procedures
To create an ordinate dimension
Grips Editing
Ordinate dimensions can be edited directly through grips:
  1. Select an ordinate dimension. Notice the grips.
  2. Drag the grips to perform the following actions:
DimLeader and Leader - places leaders with text, blocks, entities, or tolerances.
