VPoint
Changes the 3D viewpoint.
command bar:  vpoint
transparent:  'vpoint
aliases:  viewpoint, -vp, -viewpoint, -vpoint
menu bar:  View | Look From
toolbar:  Look From
: vpoint
Plan/Rotate/<View point> <0.0, 0.0, 0.1>: (Enter x,y,z coordinates, an option, or press Enter for dialog box.)
Specifies the viewpoint by x,y,z coordinates.
To view an isometric viewpoint, enter -1,-1,1.
View point
Displays the Set Viewpoint dialog box; see DdVPoint command.
Plan
Displays the plan view of the current UCS; prompts you:
Plan view of: UCS/World/<Current UCS> - Enter an option.
Current UCS
Displays the plan view of the current UCS.
UCS
Displays the plan view of a named UCS; prompts you:
? to list/<Name of UCS> - specify the name of the UCS.
World
Displays the plan view of the World Coordinate System.
Rotate
Changes the viewpoint by angles; prompts you:
Angle in XY plane from X axis - specify an angle, or pick two points.
Angle from the XY plane - specify an angle, or pick two points.
Look From toolbar
Lets you choose between:
Dialog Box Options
Horizontal
Vertical
Angle Precision
Sets markers at 5, 15, or 45 degrees; default = 45.
Plan
Reverts from the 3D viewpoint to 2D plan view.
Previous
Reverts to the previous viewpoint.
Set
Sets the viewpoint and exits the dialog box.
DdVPoint - changes the 3D viewpoint of the drawing through a dialog box.
DView - changes the 3D viewpoint interactively, and turns on perspective mode.
RtRot - rotates 3D drawings in real-time
