cluster
A cluster tile or container tile groups other tiles together in a dcl dialog. These are the predefined cluster tiles: dialog, cluster, row, column, boxed_row, boxed_column, radio_cluster, radio_row, radio_column, boxed_radio_column, boxed_radio_row, concatenation, paragraph.
A row is a dcl container with vertical orientation: it places all its child tiles below each other, from top to bottom.
A column is a dcl container with horizontal orientation: it places all its child tiles besides each other, from left to right.
A cluster is a general type of dcl container. It will manifest itself as either a row or a column, depending on the attribute layout. If the layout attribute is not specified, a cluster will be horizontally oriented. It is not customary to directly use a cluster: instead use a row or a column.
A dialog is a root tile that is accessed through the function new_dialog. It contains the entire hierarchy of tiles visible in the displayed dialog. The default orientation of a dialog is vertical. The layout attribute can also be specified to deviate from the default vertical orientation.
Every cluster containing radio in its name is meant to contain a set of radiobuttons. In BricsCAD, any cluster can contain a set of radio_buttons, but for compatibility with other dcl engines it can be needed to add radio_button only to a cluster with radio in its name. See radio_button for more.
Every cluster containing boxed in its name, will appear with a surrounding line or box. A cluster with a non-empty label attribute will also appear with a surrounding line, interrupted by the displayed label at the top-left of the cluster.
A concatenation is a dcl container with horizontal orientation with attributes "fixed_width = true", "fixed_height = true" and "children_alignment = centered". As a result this container places its children vertically centered along a horizontal line, without taking extra space that might be available during layouting (see also the attributes fixed_width, fixed_height, children_alignment).
A paragraph is a dcl container with vertical orientation with attribute "fixed_height = true". As a result this container places its children left aligned along a vertical line, without taking extra vertical space that might be available during layouting (see also the attribute fixed_height).
The dcl tiles concatenation and paragraph are typically used in combination with a text_part.
related attributes
callbacks
