Silent Installation (Windows only)
Silent installations are installations that run without a user
interface. A normal (non-silent) installation receives the
necessary input from the user in the form of responses to dialog
boxes. However, a silent installation does not prompt the end user
for input.
The user interface of an MSI installer (Microsoft Installer) typically queries the target system and
displays an installation wizard (Setup Wizard) which enables the
user to change various options that will affect the
installation.
The same MSI can also perform a so-called 'quiet mode' or
'silent mode' installation whereby the User Interface of the Setup
Wizard gets suppressed. This is done by running the msiexec.exe
command-line utility with the /qn option (= quite no interface) and
specifying on the command line all the information that the wizard
would normally gather. Therefore, any actions that occur within the
user interface sequence will not be performed during a 'silent'
installation.
To silently perform a BricsCAD installation
- Do one of the following:
- open a Command Window, then change the
directory (cd) to the location of the BricsCAD installer .msi
file.
- In the Windows
Explorer dialog, browse to the location, then hold down the
Shift key, right click and select Open
command window here in the context menu.
- Type msiexec /i then
do one of the following:
- type "<BricsCAD
installer filename>" (e.g.
"BricsCAD-Vxx.x.xx-x-en_US(x64).msi").
- drag the BricsCAD installer file from the
Windows Explorer dialog onto the
command window.
- Type /qn
at the command prompt.
- (option) To suppress the adding of a Desktop
Shortcut:
add ADDDESKTOPSHORTCUT="".
- (option) To suppress the display of the Release
Notes when the installation completes:
add SHOWRELEASENOTES="".
- (option) To install BricsCAD in a specific folder,
different from the default folder:
add APPLICATIONFOLDER="your_app_folder"
- (option) To specify a folder for the license file
if any of the properties BRXLICENSEKEY, BRXLICENSEFILE or BRXLICENSESERVER are defined. Default is
APPLICATIONFOLDER\BricsCAD.lic.
add BRXLICENSEDESTFILE="path_to_lic_file"
- (option) To activate the license and store it in
the folder specified by BRXLICENSEDESTFILE:
add BRXLICENSEKEY="your_license_key"
- (option) To copy the license file to the folder
add BRXLICENSEFILE="your_license_file"
- (option) To create a license file in the folder
specified by BRXLICENSEDESTFILE,
containing the server host specification:
add BRXLICENSESERVER="host", or
BRXLICENSESERVER="port@host" if your
license server is using a different port than the default port,
being 5053.
- (option on 32 BIT only) To not install VBA:
add INSTALLVBA="0" or INSTALLVBA=""
The complete entry at the command prompt might be:
msiexec /i
"BricsCAD-Vxx.x.xx-x-en_US(x64).msi" /qn ADDDESKTOPSHORTCUT=""
SHOWRELEASENOTES=""
- Press Enter to launch the installation.
NOTES
For more options, type: msiexec /?
On the Microsoft website, you can find more information about the msiexec command.
Related
topics
Installation
Increase the memory
limit
© Menhirs NV. All rights reserved. |
