Platinum
Platinum
Platinum
Drags major faces of solids while preserving connections with minor faces. Drags minor faces; optionally connects minor faces to major faces of other solids.
command bar: bimdrag
menu bar: BIM | Drag
toolbar: BIM | ![]()
Quad: BIM | ![]()
: bimdrag
Select several entities/subentities: (select a face of a solid)
Entities in set: 1
Select several entities/subentities: (select more faces, then right click or press Enter to stop selecting.)
Major faces (1) and minor faces (2).
Major faces |
Major Faces = 0n: Moves the selected solid, while preserving connections with other solids. Major Faces = Off: Moves the selected faces only, thus changing the thickness (width) of the solid.
Press the Ctrl-key to toggle Major Faces ON/OFF. If TIPS is ON the current state of Major Faces is indicated in the Tips widget:
Do one of the following:
Minor faces |
Moves the selected faces, thus stretches the solid; optionally connects the selected faces to the nearest major face of another solid.
If TIPS is ON the Tips widget displays:
Procedures
Modifying the thickness of a wall
Modifying the height of a wall
Setting the distance between parallel walls
dmPushPull - adds or removes volume from a solid by moving a face.
dmMove - moves the selected solids, or faces or edges of a solid using a vector.
