DmPushPull
BricsCAD (Windows) Pro, PlatinumBricsCAD (Linux) Pro, PlatinumBricsCAD (Mac) Pro, Platinum
Adds or removes volume from a solid by moving a face.
command bar:  dmpushpull
menu bar:  Model | Direct Modeling | Push/Pull
toolbar:  Direct Modeling |
: dmpushpull
Select faces to push/pull: (select one or more faces on the same or different solids; press and hold the TAB key to select hidden geometry. Press Enter to stop selecting geometry.)
The selected geometry is edited dynamically.
Do one of the following:
Planar faces
The faces are moved, thus adding or removing volume from the solid(s). The value of the movement vector displays in the dynamic entry field.
Cylindrical and spherical faces
Edits the radius. The current radius displays in the dynamic entry field.
Toroidal faces
Edits the tube radius of the torus.  The current radius displays in the dynamic entry field.
Operations
To control dimensions
dmChamfer - creates an equal distance chamfer between adjacent faces sharing a sharp edge.
dmDelete - deletes faces and solids.
dmExtrude - creates a 3D solids by extruding closed 2D entities or regions.
dmFillet - creates a smooth fillet between adjacent faces sharing a sharp edge.
dmMove - moves the selected faces or edges of a solid using a vector.
dmRevolve - Creates 3D solids by revolution of closed 2D entities or regions about an axis.
dmRotate - rotates faces of a solid around an axis.
BimDrag - drags major faces of solids while preserving connections with minor faces. Drags minor faces; optionally connects minor faces to major faces of other solids.
