Camera
Creates perspective views.
command bar:  camera
menu bar:  View | Camera
toolbar:  View |
: camera
Specify camera location: (Enter a point to specify the location of the camera)
Specify target location: (Enter a point to specify the location of the target)
Enter an option: ?/Name/LOcation/Height/Target/LEns/Clipping/View/<eXit>: (Enter an option or press Enter to conclude the command
A Camera glyph displays in the drawing to indicate the position of the camera.
A saved view is created in the drawing.
Name
Prompts you:
Enter name for new camera <Camera1>: Type a name for the saved view or press Enter to accept the default name.
Location
Repositions the camera. Prompts you:
Specify camera location <x,y,z>: Do one of the following:
  • Pick a point in the drawing.
  • Type the x-, y- and z-coordinates in the command bar, then press Enter.
Height
Sets the Z-coordinate of the camera location. Prompts you:
Specify camera height <current height>: Enter a value.
Target
Repositions the target. Prompts you:
Specify target location <x,y,z>: Do one of the following:
Lens
Defines the lens length. Prompts you:
Specify lens length in mm <50.00>: Enter a value.
Clipping
Defines the front and back clipping planes. Prompts you:
Enable front clipping plane? Yes/<No>: Type Y to define the front clipping plane. Prompts you:
Specify front clipping plane offset from target plane <0.00>: Do one of the following:
  • Pick to point in the drawing.
  • Type a value in the command bar, then press Enter
Enable back clipping plane? Yes/<No>: Type Y to define the back clipping plane. Prompts you:
Specify back clipping plane offset from target plane <0.00>: Do one of the following:
View
Sets the camera view current. Prompts you:
Switch to camera view? Yes/<No>: Type Y, then press Enter.
Editing a Camera
Properties of a camera view can be edited:
i
Grips Editing
Cameras can be edited directly through grips:
  1. Select the camera glyph in the drawing. Notice that it has three grips.
    Front (F) and back (B) clipping planes display in a blue dotted line.
  2. Drag the grips to perform the following actions:
  3. Position the camera (1).
  4. Move the camera definition as a whole (2).
  5. Position the target (3).
DView - changes the 3D viewpoint interactively, and turns on perspective mode.
View - creates and sets named views through the Drawing Explorer.
