Ellipse
Draws ellipses and elliptical arcs.
command bar:  ellipse
alias:  el
menu bar:  Draw | Ellipse or Draw | Elliptical Arc
toolbar:  Draw | or Draw |
: ellipse
Arc/Center/<First end of ellipse axis>: (Pick a point, or enter an option.)
Second end of axis: (Pick another point.)
Rotation/<Other axis>: (Pick a third point, or enter R.)
All methods to draw ellipses can be found in the Draw | Ellipse menu:
and the Ellipses toolbar:
All methods to draw elliptical arcs can be found in the Draw | Elliptical Arc menu:
and the Elliptical Arcs toolbar:
First End of Ellipse Axis
Specifies the first endpoint of the first axis.
Ellipses are defined by the length of two axes, or one axis and an angle of rotation.
Second End of Axis
Specifies the other end of the first axis.
Other Axis
Specifies the endpoint of the second axis, measured from the center of the first axis.
The longer of the two axes is called the "major axis"; the shorter one is called the "minor axis."
Arc
Draws elliptical arcs; prompts you:
Center - specify the center point of the elliptical arc.
First end of ellipse axis - specify the endpoint of the elliptical arc's first axis.
Parameter
Specifies parameters for the parametric formula that crafts the elliptical arc:
p(b) = c + a * cos(u) = b * sin(u)
where:
a = major axis.
b = minor axis.
c = center of the ellipse.
u = point along the arc.
Cos and Sin are the trigonometric cosine and sine functions.
Start Angle of Arc
Specifies the start angle, creating the arc's starting point.
The angles are measured counter-clockwise from the positive x axis.
End Angle
Specifies the end angle, creating the arc's endpoint.
Included
Specifies the included angle, measured from the starting point.
Center
Draws the ellipse starting with a center point; prompts you:
Center of ellipse - pick a point, or enter x, y coordinates.
Endpoint of Axis
Specifies the endpoint of one axis, measured from the center point.
Other Axis
Specifies the endpoint of the other axis, also measured from the center point.
Rotation
Specifies the angle of the ellipse; prompts you:
Rotation around major axis - pick a point, or enter an angle between 0 and 89.9 degrees.
An angle of 0 degrees draws a circle; 89.9 draws a very thin ellipse.
Procedures
Setting the Polyline Ellipse (PELLIPSE) variable
General procedure to draw an ellipse
General procedure to draw an elliptical arc
Editing an ellipse
Editing an elliptical arc
Grips Editing
Ellipses can be edited directly through grips:
  1. Select the ellipse. Notice that it has five grips.
  2. Drag the grips to perform the following actions:
Arc - draws circular arcs.
Isoplane - change the working isoplane for drawing isometric entities, including isocircles.
Properties - changes the properties of ellipses through a palette.
