Clips images.
command bar: imageclip
transparent: 'imageclip
alias: icl
menu bar: Modify | Raster Image | Clip Image
toolbar: Images | ![]()
: imageclip
Enter image clipping option [ON/OFF/Delete/New] <New>: (Enter an option, or press Enter to create a new clipping boundary.)
Enter image clipping type [Polygonal/Rectangular] <Rectangular>: (Type P or R.)
Specify first corner: (Pick one corner of the clipping rectangle.)
Specify opposite corner: (Pick other corner of the clipping rectangle.)
This figure shows the clipped portion faded for illustrative purposes; in BricsCAD, the clipped portion is invisible.
An image can have just one clipping boundary; creating a new one erases the old one.
Determines the clipping action:
Creates a rectangular clipping boundary; prompts you: Specify first corner - specifies the first corner of the clipping rectangle. Specify opposite corner - specifies the other corner of the clipping rectangle. |
Creates a multi-sided, polygonal boundary; prompts you: Start of polyline - specifies the starting point of the clipping boundary. Next point - specifies the next point; as you pick points, BricsCAD previews the boundary. Undo/Next point - specifies the next point, or undoes the last one; this prompt repeats until you press Enter.
This prompt appears only when you specify the New option for an image that already contains a clipping boundary.
Grips Editing
Clipped images can be edited directly through grips:
Select the image frame. Notice that it has several grips.
Drag a grip to stretch the frame, which changes the path of the clipping boundary.
Procedures
To toggle the clipping boundary of an image
-ImageAttach - attaches raster images to the drawing; displays prompts in the command bar.
