Reports the BricsCAD license information in a dialog box.
Allows to modify or deactivate a BricsCAD single user or volume license key.
command bar: licproperties
transparent: 'licproperties
menu bar: Help | BricsCAD License...
: licproperties
Review license information, and then click OK.
Deactivates the license key. BricsCAD can no longer be used on this computer. The license key is available for activation on another computer. An internet connection is needed to deactivate a license key. You must deactivate a license key:
Allows to specify proxy settings if your computer connects to the internet through a proxy server.
Displays the Activate BricsCAD dialog box. See LicEnterKey command. |
Status - reports on the state of the drawing.
LicEnterKey - changes the license number and owner.
