Allows to control the display of layers in a PDF underlay.
command bar: pdflayers
: pdflayers
Select PDF underlay: (Choose a pdf underlay.)
BricsCAD displays a dialog box:
Select a different PDF underlay. |
Type a search string in the search field. Only layers of which part of the layer name matches the search string are listed. You can use wildcards (? or *) in the search field. |
Click the column title to sort the layer list by display. |
Click the icon to turn the display of a layer on/off. |
Click the column title to sort the layer list by name. |
Procedures
To set the layer display in a PDF underlay
PdfAdjust - Allows to adjust the fade, contrast and monochrome settings of a PDF-underlay in the command bar.
pdfattach - inserts a PDF file as an underlay into the current drawing.
-PdfAttach - inserts a PDF file as an underlay into the current drawing; displays prompts in the command bar.
pdfclip - clips a PDF underlay.
