ScrollBar
Toggles the display of the scroll bars.
command bar:  scrollbar
transparent:  'scrollbar
menu bar:  View | Scrollbars
: scrollbar
WNDLSCRL is currently on: OFF/Toggle/<On>: (Enter an option.)
  1. Vertical scrollbar
  2. Horizontal scrollbar
Scroll bars are useful for panning the drawing without using the Pan command:
The only reason to turn off scroll bars is to gain a bit more drawing area.
OFF
Turns off the scroll bars.
Toggle
Toggles the display of scroll bars:
  • If on, turns them off.
  • If off, turns them on.
On
Turns on the scroll bars.
CommandLine - shows the command line.
CommandLineHide - hides the command line.
GraphScr - brings the graphics window to the foreground.
StatBar - toggles the display of the status bar.
TextScr - brings the text window to the foreground.
Toolbar and -Toolbar - toggle the display of toolbars.
