StatBar
Toggles the display of the status bar (short for "status bar").
command bar:  statbar
transparent:  'statbar
shortcut:  Shift + F3
menu bar:  View | Status Bar
: statbar
WNDLSTAT is currently on: OFF/Toggle/<On>: (Enter an option.)
The status bar provides useful information and controls:
  1. Status field:
  2. displays a tooltip when hovering over a tool button
  3. displays command prompts when the command bar is closed
  4. double click the status field to toggle the command bar on/off
  1. Coordinates field
  2. Drawing properties
  3. Drawing aids
  4. Status bar option button.
    Displays a list: Click an option to toggle the corresponding field on/off.
The only reason to turn off the status bar is to gain a bit more drawing area.
Procedures
Working with the status bar
CommandLine - shows the command line.
CommandLineHide - hides the command line.
GraphScr - brings the graphics window to the foreground.
Scrollbar - toggles the display of the scroll bars.
TextScr - brings the text window to the foreground.
Toolbar and -Toolbar - toggle the display of toolbars.
