SectionPlaneSettings
BricsCAD (Windows) Pro, PlatinumBricsCAD (Mac) Pro, PlatinumBricsCAD (Linux) Pro, Platinum
Defines the properties of a section plane entity in the Drawing Explorer - Section Planes dialog.
command bar:  sectionplanesettings
menu bar:  Tools | Drawing Explorer | Section Planes
Displays a dialog:
Details Panel
New
Launches the SectionPlane command to create a new section plane defintion.
Delete
Deletes the currently selected section plane definition.
Section Plane Name
Double click the field to rename the section plane.
Live Section
Click the checkbox to switch the live section property of a section plane on/off.
State
Indicates the state of the section plane.
The image below shows a 3D solid (red) and the position and size of the section plane entity (green)
The options are:
  • Plane: The cutting plane and the section line display.
    The cutting plane extends infinitely in all directions.
    The cut-away volume displays transparently in blue.
    If a Plane state is applied to a jogged section plane entity, the first segment of defines the cutting plane.
  • Boundary: The cutting plane and a 2D box, indicating the extents of the cutting plane in the XY-plane, display.
    The cutting plane extends infinitely in the Z-direction.
  • Volume: the cutting plane and a 3D box, indicating the 3D  extents of the cutting plane, display.
Plane Transparency
Sets the transparency of the cutting plane in the drawing.
Plane Color
Sets the color of the cutting plane in the drawing.
The color of the section line is defined by the Color property of the section plane entity.
Edit panel
If you Select multiple section definitions, you can edit them simultaneously. If a setting is defined differently in the selected section definitions, the setting field reads *varies*.
2D Section / elevation block creation settings
Select multiple section plane entities to define their settings simultaneously.
3D Section block creation settings
Live section settings
LiveSection - switches the Live Section property of a section plane on or off.
Section - creates section planes of 3D solids; the results are region entities.
SectionPlane - creates a section entity that creates sections of 3D solids.
SectionPlaneToBlock - saves the selected section plane to a 2D cross section / elevation block or a 3D cutaway section block.
