Configures and calibrates tablets, and toggles tablet mode.
command bar: tablet
shortcut: T
alias: ta
menu bar: Settings | Tablet
status bar: TABLET
: tablet
Tablet: ON/OFF/CALibrate/ConFiGure/<On>: (Enter an option.)
This command requires that Wintab32.dll from Wacom Technology, Corp. be installed on the computer.
Download Wintab32.dll from the internet, then place the file in your system directory: C:\Windows\System32.
Turns on tablet digitizing mode. The entire surface of the table is used like a mouse for picking points and selecting entities. |
Turns off tablet digitizing mode. The menu areas become available for selecting commands. |
Calibrates the coordinates of the tablet. |
Configures the tablet's menu areas. |
Right-click TABLET on the status bar for the shortcut menu:
Shortcut Menu |
Turns on tablet digitizing mode. |
Turns off tablet digitizing mode. |
Opens the Coordinate Input section of the Settings dialog box.
Tablet mode |
Toggles tablet mode:
Procedures
To use a digitizing tablet in BricsCAD
To download the tablet overlay and CUI files
None.
