Undo
Undoes one or more commands; some commands cannot be undone.
command bar:  undo
toolbar: Standard |
: undo
Undo:  Mark/Back to mark/BEgin set/End set/Control/Auto/<Number of steps to undo>: (Enter the number of commands to undo, or enter an option.)
BricsCAD reports the commands being undone. For example, enter the Customize and then the Units commands. Enter Undo:
Undo: (UNITS)
Undo: (CUSTOMIZE)
Specifies the number of commands to undo.
Enter a number.
Commands are undone sequentially; you cannot skip over commands.
Some commands cannot be undone, such as Save, Open, and Plot.
Mark
Sets a marker.
The Back to mark option undoes all commands to the marker.
Back to mark
Undoes all commands back to when the marker was set.
BEgin set
Sets the start to a group that groups the following commands.
The Undo command treats the commands in the set as a single undo.
End set
Ends the group.
Control
Specifies options; prompts you:
Set Undo control: None/One/<All> - enter an option.
None
Turns off the undo mechanism.
This is useful when disk space is running low, because the undo mechanism uses disk space.
One
Limits this command to a single undo.
This option turns the Undo command into the U command.
All
Turns on the undo mechanism.
Auto
Considers all commands executed by a macro as a single undo.
The Undo control settings are stored in the UNDOCTL system variable, which is saved as a bitcode using the sum of the values of all selected options.
In BricsCAD four options are available:
By default UNDOCTL=5. Since the value of UNDOCTL is not saved, the value is reset to the default with each BricsCAD session.
In AutoCAD two more options exist:
BricsCAD behaves as if those options are ON.
U - undoes the last command.
Redo - redoes the last undone command.
Oops - unerases the last erased object, including newly created blocks.
Zoom - utilizes the Previous option to show the previous view.
