To see a complete list of all System variables:
Type setvar in the
command window followed by Enter.
The command bar reads: Variable name or ?:
Type ? (question
mark) in the command bar, then press Enter.
The command bar reads: Variable(s) to list <*>:
Press Enter.
The BricsCAD Prompt History window
opens, listing all variables and their current value.
Categorized
Lists the settings by category: Drawing, Dimensions and Program Options.
Alphabetical
Lists the settings alphabetically.
Drawing (
Opens the Categorized view mode, with the Drawing tree expanded.
Dimensions (
Opens the Categorized view mode, with the Dimension tree expanded.
Program Options
Opens the Categorized view mode, with the Program Options tree expanded.
Use the search field to find a setting.
Understanding the Settings dialog
The Settings dialog gives you an overview of all System variables and user preferences and their current value.
Here you can:
1 |
Class: Drawing, Dimensions or Program Options |
2 |
Category (expanded) |
3 |
Sub-category (expanded) |
4 |
Group (expanded) |
5 |
Current value of a system variable |
6 |
Options list |
7 |
Internal Name: System variable names are fully capitalized: LUNITS User preference names are mixed case: TemplatePath You can type system variables and user preferences in the command window to edit them or use the SETVAR command (system variables only). |
8 |
Variable Title |
9 |
Variable Help |
10 |
Preview (if available) |
11 |
Settings Type ( |
12 |
Save location
NOTE |
If you check all Find where options in step 2, it might take longer to find the variable you are looking for, since more variables match the content of the Find what field. |
Editing settings in the command bar
The command bar reads: New current value for AUTOSNAP (0 to 63) <63>:
NOTES |
