Units
Sets units of linear and angular measurements through the Settings dialog box.
command bar:  units
transparent:  'units
alias:  un, ddunits
status bar:  X,y,z-coordinates
: units
Displays the Drawing Units section of the Settings dialog box:
Change settings, and then click the X button.
Insertion Units
Defines a real world value for 1 drawing unit.
The INSUNITS system value must be defined properly for automatic scaling when inserting external blocks, images or Xrefs.
Select a unit:
Measurement
Defines which default source files will be used when loading linetypes and predefined hatch patterns (see the Hatch command).
Select an option:
  • Imperial: uses default.lin and default.pat
  • Metric: uses iso.lin and iso.pat
BricsCAD searches for the default hatch and linetypes files in the folders which are defined by the SRCHPATH system variable.
Default support file search path: C:\Users\<username>\AppData\Roaming\Bricsys\Bricscad\V..\en_US\Support
Unit mode
Specifies how imperial units display.
Suppress dim zeros
Allows to suppress leading and / or trailing zeros in decimal dimensions.
Allows to suppress zero feet and zero inches in imperial dimensions.
Linear unit type
Specifies the units of linear measurement. Select a unit:
  • Scientific - such as 4.225E+01
  • Decimal - such as 42.25
  • Engineering - such as 3'-6.25"
  • Architectural - such as 3'-6 1/4"
  • Fractional - such as 42 1/4
For metric units, choose 2 (decimal).
Linear unit precision
Specifies the number of decimal places. Enter a number between 0 and 8:
  • 0 - 0 decimal places, such as 0.
  • 1 - 1 decimal places, such as 0.0
  • 2 - 2 decimal places, such as 0.00
  • 3 - 3 decimal places, such as 0.000
  • 4 - 4 decimal places, such as 0.0000
  • 5 - 5 decimal places, such as 0.00000
  • 6 - 6 decimal places, such as 0.000000
  • 7 - 7 decimal places, such as 0.0000000
  • 8 - 8 decimal places, such as 0.00000000
This option affects the precision of fractions in architectural and fractional units:
  • 0 - 0 fractional precision, such as 1
  • 1 - 1/2
  • 2 - 1/4
  • 3 - 1/8
  • 4 - 1/16
  • 5 - 1/32
  • 6 - 1/64
  • 7 - 1/128
  • 8 - 1/256
Angular unit type
Specifies the type of angular units. Select a unit:
  • Decimal degrees - such as 90.0.
  • Degrees/minutes/seconds - such as 90d0'0.
  • Gradians - such as 100.00g. There are 400 grads in a circle.
  • Radians - such as 1.57r. There are 2*pi radians (approximately 6.282) in a circle.
  • Surveyor's units -  such as N 00d0'0"E. The N and E in Surveyor's units refers to North and east.
Angular unit precision
Enter a number between 0 and 8.
Angle base
Specifies the direction for 0 degrees. The default is the positive x axis.
Enter an angle. You can also rotate the drawing through the Snap command's Rotate option.
Angle direction
Toggles the direction in which angles are measured:
  • No - measures angles counterclockwise (default).
  • Yes - measures angles clockwise.
Status Bar Menu
Right-click 72',42',0" (or other x,y,z coordinates) on the status bar for the shortcut menu:
Shortcut Menu
Scientific Linear Units
Chooses scientific as the working units.
Decimal Linear Units
Chooses decimal (metric) as the working units.
Engineering Linear Units
Chooses engineering as the working units.
Architectural Linear Units
Chooses architectural as the working units.
Fractional Linear Units
Chooses fractional as the working units.
Relative
Displays relative coordinates in the status bar.
Absolute
Displays absolute coordinates in the status bar.
Off
Displays coordinates only when points are picked.
Properties
Opens the Coordinates section of the Settings dialog box.
Coordinates
Specifies how coordinates are displayed in the status bar:
  • Update coordinates only when selecting points - equivalent to Off.
  • Coordinates always show pointer location - equivalent to Absolute.
  • Coordinates in polar form for point, distance and angle selection - equivalent to Relative.
-Units - sets units through the command bar.
NewWiz - sets units and other parameters for new drawings.
New - starts new drawing in Imperial or metric units.
