Starts new drawings with the New Drawing Wizard.
command bar: newwiz
alias: ddnew
menu bar: File | New Wizard
: newwiz
Displays a dialoDefaultTemplateg box:
Choose an option, and then click Next.
Press F1 to access help.
Starts new drawings using one of the default template files associated with these design context and measurement systems:
Choose a measurement system, and then click Finish:
Starts new drawings with a template file:
Choose a template file. Optionally check the Use the selected template as default option. Then click Finish. STB is short for "style table," which refers to template drawings with plot styles. |
Starts new drawings with the default template as defined by the BASEFILE system variable. |
Starts new drawings with a wizard:
Check the Set Workspace option, then select a workspace from the list button.
Choose a linear measurement unit, and then click Next.
Choose an angular measurement unit, and then click Next.
Choose whether the drawing uses color-dependent plot styles or named plot styles:
Click Next.
Choose the default working color and linetype:
Toggle the grid, snap, UCS icon, and marker blips:
Click Finish. |
Procedures
To create a drawing using a default template drawing
To set the default template drawing
To create a drawing from scratch
To create a drawing using a template drawing
To create a drawing using the New command
To set the Template Path variable
To create a drawing using a wizard
Units - sets units through the Settings dialog box.
-Units - sets units through the command bar.
New - starts new drawing in Imperial or metric units.
QNew - opens new drawings.
