Class AcadSelectionSet
Member of BricscadApp
The SelectionSet object represents one or more drawing entities which can be operated on as a single unit. To access the SelectionSet object, use the following methods and properties:
Methods | Properties |
AddItems | Application |
Clear | Count |
Copy | Name |
Delete | Visible |
Erase | |
Highlight | |
Item | |
RemoveItems | |
Select | |
SelectAtPoint | |
SelectByPolygon | |
SelectOnScreen | |
Update | |
ScaleEntity |
© Menhirs NV. All rights reserved. |
