Sets (where applicable) and returns the name of an object, such as the application, document, block, layer, view.
Syntax
Where:
stringVariable is a variable for storing the Name property.
object is an Application, Block, Document, DimStyle, Layer, Linetype, SelectionSet, TextStyle, UserCoordSystem, View, or Viewport object.
Read-only for the following objects:
Application, Document, MenuGroup, ModelSpace, PaperSpace, SelectionSet, TextStyle.
Read/Write for the following objects:
Block, BlockRef, Dictionary, DimStyle, Group, Layer, Layout, Linetype, Material, MLeaderStyle, PlotConfiguration, PopupMenu, Raster, RegisteredApplication, Section, Shape, Toolbar, ToolbarItem, UCS, View, Viewport, XRecord.
Examples...
© Menhirs NV. All rights reserved. |
