Solid3D object
Class Acad3DSolid
Member of BricscadDb
To access the Solid3D object, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular Centroid
Boolean Document
CheckInterference Handle
Copy HasExtensionDictionary
Delete History
GetBoundingBox Hyperlinks
GetExtensionDictionary Layer
GetXData Linetype
Highlight LinetypeScale
IntersectWith Lineweight
Mirror Material
Mirror3D MomentOfInertia
Move ObjectID
Rotate ObjectName
Rotate3D OwnerID
ScaleEntity PlotStyleName
SectionSolid Position
SetXData PrincipalDirections
SliceSolid PrincipalMoments
TransformBy ProductOfInertia
Update RadiiOfGiration
  ShowHistory
  SolidType
  TrueColor
  Visible
  Volume
