Verifying Table + Dictionary Entries
Due to language limitations of AutoCAD
AutoLISP, there are very restricted possibilities to verify the
existence of table and dictionary entries.
Usual Lisp code to verify TABLE items :
(if (tblsearch ...)
(if (not (tblsearch ...)) ...
and similar, in conjunction with boolean expressions and comparisons
Suggested and faster method :
a) (if (tblobjname
b) (if (vle-tblsearch ...)...
(tblobjname) is faster on all systems, as it
does not generate the entget-like definition-list as (tblsearch)
does (which involves data list generation and conversion at C/C++
and Lisp level again) - instead it only returns the entity name of
the table item;
(vle-tblsearch) does not even need to wrap the
entity name (a C/C++ ObjectId) into a Lisp ENAME, which also costs
performance;
If only the "boolean" information is needed
about the presence of a table item, but not its definition-data,
then this approach saves lot of performance and memory.
AutoCAD :
(vle-tblsearch) is provided by emulation
via
"vle-extension.lsp" - so there is no
performance gain (but also no performance loss) under AutoCAD, but
Lisp code remains compatible and uniform.
Usual Lisp code to verify DICTIONARY items
(if (dictsearch ...)
(if (not (dictsearch ...)) ...
a) (if (vle-dictsearch
b) (if (vle-dictobjname ...)...
BricsCAD :
both functions are faster, as it does not
generate the entget-like definition-list as (dictsearch) does
(which involves data list generation and conversion at C/C++ and
Lisp level again) - instead they only return a boolean result resp.
the entity name of the dictionary item;
(vle-dictsearch) does not even need to wrap
the entity name (a C/C++ ObjectId) into a Lisp ENAME, which also
costs performance;
about the presence of a dictionary item, but not its
definition-data, then this approach saves lot of performance and
memory.
AutoCAD :
both functions are provided by emulation
via
