Using Database Transactions and Display Control
There are more BricsCAD-specific functions
provided to improve overall performance with intensive database
operations (creating, modifying, erasing entities, tables,
dictionaries etc.) - BricsCAD Lisp engine allows to use database
transactions which are otherwise only available for C/C++ code
(based on ARX/BRX APIs).
A Database
Transaction puts all operations into a
kind of "group", while all usual reactor mechanisms are delayed
until the transaction is finished; without transaction placed
around, all reactor mechanisms will operate "per entity", which is
often not necessary, as the final result only matters.
the usual Lisp code with transaction looks
like this :
(vle-start-transaction)
intensive database
operations
(vle-end-transaction)
All the visual updates will happen after
(vle-end-transaction), any visual update in-between is suppressed
Database Transaction is a very powerful
feature - depending on the context and particular operations, the
performance gain can be at factor 20...50 (and even 80 was
encountered by client developers).
Nevertheless, Lisp code using transactions
should be carefully and intensively tested !
Display-Pausing is
a kind of "lightweight" version of database transactions - in this
case, only the display updates are blocked until Display-Pausing is
ended; the database modifications are not grouped into a single
action, but operate normally on per-entity base.
This also provides a significant performance
improvement in many cases.
the usual Lisp code with display-pausing looks
like this :
(vle-displaypause t)
intensive database
operations
(vle-displaypause
nil)
(vle-displaypause t) starts the display
buffering - the screen is only updated by matching
(vle-displaypause nil.
Both mechanisms are fault-tolerant in
BricsCAD's Lisp engine - any pending ("open") database transaction
or display pause is automatically closed + cleared when outermost
Lisp execution finishes; even in case of Lisp errors, when
(vle-end-transaction) or (vle-displaypause nil) are not reached by
the code flow, the Lisp engine will automatically cleanup these
pending operations.
AutoCAD :
transaction-and display-pausing functions are
provided for code compatibility by
"vle-extension.lsp" - but they are
No-Operations, and simply do nothing.
