Layouts
Command: LAYOUT
In BricsCAD, you can create up to 255 layouts in a single
drawing. Each layout represents a sheet of paper. For each layout
you can specify the print area, print scale, lineweight scale, pen
mappings, and add viewports, dimensions, a title block, and other
geometry specific to the layout. The entities you add to a layout
in paper space do not appear in model space.
Each layout requires at least one layout viewport. If the
CREATEVIEWPORTS
system variable is ON a viewport is added automatically in a new
layout. If this variable is OFF, newly created viewports are empty.
To add new layouts you can either define them yourself or your can
import layouts from another drawing: template file (.dwt), drawing
file (.dwg) or drawing interchange file (.dxf).
Viewports can display all or part of the drawing’s model
space entities.
The CACHELAYOUT
system variable controls whether the content of layouts is cached.
The extra memory required for caching is made up for by
improvements to the memory requirements for displaying entities,
the net result being that the memory needed to display drawings has
been reduced. As a result of this switching between layouts is up
to 10 times faster now.
Creating a new layout
- Do one of the following:
- Click the New
Layout tool button (
) on the Layout or the Insert toolbar.
- Choose New
Layout in the Insert
menu.
- Type layout in
the command bar, press Enter, then type N and press Enter.
The command bar reads: Enter a layout name.
<Layout1>:
- Type a unique name for the layout, then
press Enter.
The name can be up to 255 characters in length and can contain
letters, numbers, the dollar sign ($), hyphen (-), and underscore
(_), or any combination.
- Right click or press Enter to accept the
default name (e.g. Layout1).
The new layout tab is added.
- Create at least one viewport (see Creating
viewports in a layout).
If the CREATEVIEWPORTS
layout.
Copying layouts
- Right click the layout tab you want to copy.
A context menu displays.
- Choose Copy in the
context menu.
The command bar reads: Enter new layout name:
- Type a new unique name in the command bar, then
press Enter.
A copy of the selected layout is added.
Arranging the layout tabs
Drag the layout tab to the desired position
or
- Right click the layout tab you want to move.
- Choose Move
Right.
- Choose Move
Left.
- To move the selected layout tab do one of the
following:
- Select the number of tab positions.
- Choose Move to Last
Layout or Move to First
Layout.
Importing layouts
- Right click the Model tab or one of the layout tabs.
- Choose From
Template... in the context menu.
The Select Template From File
window opens.
- Browse to the drawing that you want to import
layouts from.
- Click the Open
button on the Select Template From
File window.
The Insert Layout(s) window
opens.
- Select the layout(s) you want to import.
Press and hold the Ctrl key to select multiple layouts.
- Click the OK button on the Insert Layout(s) window.
The selected layouts are imported.
Renaming layouts
- Double click the layout tab you want to
rename.
The Rename Layout dialog opens.
- Type a new unique name in the Name field of the Rename
Layout dialog.
on the Rename Layout dialog.
Deleting a layout
- Choose Delete in the
context menu.
The selected layout is deleted.
Deleting multiple layouts
Choose Drawing
Explorer > Page Setups... in the Tools menu.
Choose Page
Setup... in the File menu.
The Drawing Explorer - Page
Setups dialog displays.
Select the layouts you want to delete.
To select a series of layouts: select the first layout, then press
and hold the Shift key and select the last layout.
Press and hold the Ctrl-key to add/remove layouts.
Click the Delete tool
button (
) in the toolbar on the
Drawing Explorer - Page Setups
toolbar.
An alert box displays:
Press the Yes button
on the Delete Layouts alert box.
© Menhirs NV. All rights reserved. |
