Drawing Properties
Command: DWGPROPS
The Dwgprops command opens the
Drawing Properties dialog box,
showing the general information and user defined properties stored
with a drawing.
Drawing properties include: general information, summary,
statistics and user defined custom properties.
Drawing properties can be referenced in a
field in multiline text entities or tables.
To open the Drawing Properties
dialog
do one of the following:
- Choose Drawing
Properties... in the File
menu.
- Type dwgprops
in the command bar and press Enter.
Defining default properties
- Open the Drawing
Properties dialog.
- Open the Summary tab
page.
- Fill out the property fields
- Click the OK
button.
Adding custom properties
- Open the Drawing
Properties dialog.
- Open the Custom tab
page.
- Click the Add
button.
The Custom Property dialog
displays.
- Type a name in the Name field.
The custom property name is listed under Document in the Field dialog.
- Type a value in the Value field.
The value displays in
multiline texts where the custom property is inserted as a
field.
© Menhirs NV. All rights reserved. |
