Pro, Platinum
Pro, Platinum
Pro, Platinum
Extrudes 2D entities to 3D solids.
command bar: extrude
alias: ext
menu bar: Model | 3D Solids | Extrude
toolbar: 3d Solids | ![]()
: extrude
Select entities: (Choose one or more closed 2D entities.)
Entities in set: 1
Select entities: (Choose more entities, or press Enter to continue.)
Specify height of extrusion or Path: (Enter a number, pick two points to show the height, or type P.)
Specify angle of taper for extrusion <0>: (Enter a number, or pick two points to show the angle.)
Any closed 2D entity can be extruded, including regions.
The resulting entity is a 3D solid.
Depending on the value of the DELOBJ (Delete Entity) system variable, the defining entities are either retained or deleted or you are prompted whether to keep or delete the source entities.
Grips Editing
Extrusion can be edited directly through grips:
Select the extruded solid. Notice that it has two grips.
Drag a grip to move the extrusion. (Both grips perform the same functions: move.)
dmExtrude - creates a 3D solids by extruding closed 2D entities or regions.
Loft - creates 3D solids passing through two or more cross sections.
Sweep - creates a 3D solid by sweeping a closed 2D entity along a path.
