Pro, Platinum
Pro, Platinum
Pro, Platinum
Performs Boolean intersection operations on 3D solids and 2D regions; removes all but common portions.
command bar: intersect
alias: in
menu bar: Model | 3D Solid Editing | Intersect
toolbar: 3D Solid Editing |
: intersect
Select ACIS object to intersect: (Choose one 3D solid and/or 2D region.)
Entities in set: 1
Select ACIS object to intersect: (Choose another 3D solid and/or 2D region.)
Entities in set: 2
Select ACIS object to intersect: (Choose more ACIS entities, or press Enter to perform the intersection.)
BricsCAD removes all but common volumes and areas from the selected entities: left = selected entities; right = result.
This command also applies to regions:
Caution: if solids and regions do not intersect, BricsCAD erases them.
Specifies the 3D solids and/or 2D regions. Choose one or more entities; non-ACIS entities are ignored. |
Region - creates 2D regions from 2D entities.
