Pro, Platinum
Pro, Platinum
Pro, Platinum
Pro: Shows volumes and areas of interference between ACIS entities.
Platinum: Shows volumes of interference between Acis solids.
Optionally creates new Acis Solids from the common portions of pairs of intersecting solids.
command bar: interfere
alias: inf
menu bar: Model | 3D Solids| Interfere and Model | X-Solids | Tools| Interfere
toolbar: 3D Solids | ![]()
: interfere
Select first set of Acis objects or [Nested selection] <Nested selection>: (Choose one or more 3D solids or 2D regions.)
Entities in set: 1
Select first set of Acis objects or [Nested selection] <Nested selection>: (Choose more ACIS entities, or press Enter to continue.)
Select second set of Acis objects or [Nested selection] <Nested selection>: (Choose one or more 3D solids or 2D regions.)
Entities in set: 1
Select second set of Acis objects or [Nested selection] <Nested selection>: (Choose more ACIS entities, or press Enter to continue.)
Create interference solids? Yes/<No>: (Type Y or N.)
Interfering pairs: xx
Highlight pairs of interfering solids? Yes/<No>: (Type Y or N.)
The interference solid remains in the drawing when the command ends.
Specifies the first set of ACIS entities. Choose one or more 3D solids and/or 2D regions. |
Specifies the second set of ACIS entities. Choose one or more 3D solids and/or 2D regions. The entities in the first set are compared with the entities in the second set. |
Allows to selected ACIS entities inside blocks or Xrefs; Prompts you: Select nested Acis objects for first set [eXit] <eXit> - select a nested ACIS entity. Entities in set: 1 Select nested Acis objects for first set [eXit] <eXit> - select mored nested ACIS entities or press Enter to proceed. |
Determines whether a solid or region of the interference is created:
The solid or region remains after the command ends. |
Allows to highlight each pair of intefering ACIS entities; prompts you: Highlight pairs of interfering solids? Yes/<No> - choose Yes to start highlight pairs or No to conclude the command. Enter an option [Next pair/eXit] <Next pair> - choose an option:
Region - creates 2D regions from 2D entities.
