Platinum
Platinum
Platinum
Converts local components to external components.
command bar: bmexternalize
menu bar: Assembly | Switch Component to External
ribbon: Assembly | Modify | External ![]()
toolbar: Assembly | ![]()
: bmexternalize
Select component instances [ASk for file names/Entire model] <Entire model>: (Select a local component.)
Entities in set: 1
Select component instances [ASk for file names/Entire model] <Entire model>: (Select a local component or press Enter.)
A file dialog displays:
Do one of the following:
Press the Save button to accept the default name, which is the name of the selected local component.
Type a name in the File Name field, then click the Save button.
This procedure is repeated for each of the selected local components.
For each of the local components in the assembly a file dialog displays. Do one of the following:
You can select to ask for file names of exernalized components or generate them automatically. Prompts you: Ask for file names of external components to be saved? [Yes/No] <Yes>:
BmDissolve - dissolves a mechanical component inserted in the current drawing.
BmLocalize - converts external components to local components.
BmReplace - replaces a component insert.
