Opens new drawings in BricsCAD (short for "quick new").
command bar: qnew
alias: n
menu bar: Name
toolbar:  Standard | ![]()
: qnew
Displays a dialog box that depends on the STARTUP system variable in the Settings dialog box:
When STARTUP = 1 (Display the Startup and Create new Drawings dialog boxes), shows the following dialog box:
See NewWiz command.
When STARTUP = 2 (Display the Select Template dialog box, or use default drawing template file):
Creates a new drawing using the default template drawing defined by the BASEFILE system variable.
If the BASEFILE system variable is empty, displays the Select Template dialog box showing the content of the folder defined by the TemplatePatch user preference.
See New command.
For Create New Drawing options, see NewWiz command.
For Select Template options, see New command.
Procedures
To create a drawing using a default template drawing
To set the default template drawing
To create a drawing from scratch
To create a drawing using a template drawing
To create a drawing using the New command
To set the Template Path variable
To create a drawing using a wizard
Units - sets units through the Settings dialog box.
-Units - sets units through the command bar.
NewWiz - sets units and other parameters for new drawings.
New - opens new drawings.
