Tablet
BricsCAD (Windows)
Configures and calibrates tablets, and toggles tablet mode.
command bar:  tablet
shortcut:  T
alias:  ta
menu bar:  Settings | Tablet
status bar:  TABLET
: tablet
Tablet: ON/OFF/CALibrate/ConFiGure/<On>: (Enter an option.)
This command requires that Wintab32.dll from Wacom Technology, Corp. be installed on the computer.
Download Wintab32.dll from the internet, then place the file in your system directory: C:\Windows\System32.
ON
Turns on tablet digitizing mode.
The entire surface of the table is used like a mouse for picking points and selecting entities.
OFF
Turns off tablet digitizing mode.
The menu areas become available for selecting commands.
CALibrate
Calibrates the coordinates of the tablet.
ConFiGure
Configures the tablet's menu areas.
Status Bar Menu
Right-click TABLET on the status bar for the shortcut menu:
Shortcut Menu
ON
OFF
Settings
Opens the Coordinate Input section of the Settings dialog box.
Tablet mode
Toggles tablet mode:
  • On - switches tablet to digitizing mode.
  • Off - switches tablet to command selection mode.
Procedures
To use a digitizing tablet in BricsCAD
To download the tablet overlay and CUI files
To load the overlay CUI file
To switch the tablet ON / OFF
To configure the tablet
To calibrate the tablet
None.
