Changes the 3D viewpoint.
command bar: vpoint
transparent: 'vpoint
aliases: viewpoint, -vp, -viewpoint, -vpoint
: vpoint
Plan/Rotate/<View point> <0.0, 0.0, 0.1>: (Enter x,y,z coordinates, an option, or press Enter for dialog box.)
Specifies the viewpoint by x,y,z coordinates. To view an isometric viewpoint, enter -1,-1,1. |
Displays the Set Viewpoint dialog box; see DdVPoint command. |
Displays the plan view of the current UCS; prompts you: Plan view of: UCS/World/<Current UCS> - Enter an option. |
Current UCS |
Displays the plan view of the current UCS. |
UCS |
Displays the plan view of a named UCS; prompts you: ? to list/<Name of UCS> - specify the name of the UCS. |
World |
Displays the plan view of the World Coordinate System. |
Changes the viewpoint by angles; prompts you: Angle in XY plane from X axis - specify an angle, or pick two points. Angle from the XY plane - specify an angle, or pick two points. |
Look From toolbar
Lets you choose between:
6 orthographic views: Front, Left, Back, Right, Top and
Bottom.
Click the center button to choose between Top and Bottom in the
flyout.
4 isometric views: Front Left, Back Left, Back Right and Front Right.
Dialog Box Options
Horizontal |
Vertical |
Angle Precision |
Sets markers at 5, 15, or 45 degrees; default = 45. |
Plan |
Reverts from the 3D viewpoint to 2D plan view. |
Previous |
Reverts to the previous viewpoint. |
Set |
Sets the viewpoint and exits the dialog box. |
DdVPoint - changes the 3D viewpoint of the drawing through a dialog box.
DView - changes the 3D viewpoint interactively, and turns on perspective mode.
RtRot - rotates 3D drawings in real-time
