Circles
Command: CIRCLE, AI_CIRCTAN
The default method for drawing a circle is to specify a center point and radius.
Other methods to draw circles can be found in the Circle submenu of the Draw menu and in the Circles toolbar.
The Ai_CircTan command draws circles tangent to three entities.
General procedure to draw a circle
  1. Do one of the following.
  2. Click the Circle tool button () on the Draw toolbar.
  3. Type circle in the command bar, then press Enter.
  4. Type C in the command bar, then press Enter.
You are prompted: 2Point/3Point/RadTanTan/Arc/Multiple/<Center of circle>:
A prompt menu displays:
  1. Specify the center point of the circle.
    You are prompted: Diameter/<Radius> <current radius>:
    The prompt menu changes:
  2. Do one of the following:
  3. Press Enter to accept the current radius.
  4. Type a new radius and press Enter.
  5. Click to define the radius graphically.
Drawing a circle tangent to three entities
  1. Type ai_circtan in the command bar.
    You are prompted: Enter Tangent spec:
  2. Click a linear entity.
    Lines, arcs, circles, polyline segments, xlines and rays are accepted.
    You are prompted: Enter second Tangent spec:
  3. Click the second linear entity.
    You are prompted: Enter third Tangent spec:
  4. Click the third linear entity.
    A circle tangent to the three selected entities is created.
Editing a circle
  1. Select the circle.
    The properties of the circle display in the Properties bar.
  1. Type a new value in the Center, Radius, Diameter, Circumference or Area field, then press Enter.
  2. Press the Esc key to stop editing the circle.
