Command: PROPERTIES
In the Properties panel you can:
Set the current properties: color, layer, linetype, linetype scale and lineweight
Edit endpoints of lines and vertices of polylines graphically
Do one of the following:
Properties - No selection The
current entity properties, |
Properties - Single entity selected The properties of the selected entity display |
Properties - Multiple entities selected The shared properties of the selected entities display |
NOTE |
The Properties panel can be either floating or docked. To dock the Properties panel, drag it by its title bar to either the left or right hand side of the BricsCAD application window. |
NOTE |
Read-only fields display in grey. The content of a read-only field can be copied though. To copy a read-only field, click the field, then press Ctrl C. |
To adjust the size of the Properties panel
NOTE |
When docked, only the left (or right) edge of the Properties is adjustable. |
Setting the current properties in the Properties panel
Edit the properties of a single entity
Select the entity.
The entity's properties display in the Properties panel..
Properties of a circle |
NOTES |
To edit the endpoints of a line
NOTE |
This procedure also applies to edit the insertion point of texts, images, blocks, Xrefs, ... |
To edit the vertices of a polyline
Edit the shared properties of a selection set
NOTES |
