Commands: COMMUNICATORINFO, EXPORT, IMPORT
Assembly design using BricsCAD
Communicator
BricsCAD Communicator is an optional plug-in for the Pro and Platinum editions of BricsCAD that imports and exports 3D data between major CAD formats. Its high quality translations facilitate the re-use of 3D CAD data, thereby improving productivity and reducing project costs.
The following file formats are supported:
STE, STP, STEP: Standard for Exchange of Product data
IGS, IGES: Initial Graphics Exchange Specification
CATIA V4 and V5:
VDA: VDA-FS
3D PDF
You can export BricsCAD assembly with mechanical components as a STEP file with product structure. To do that set the desired value in Settings dialog:
ACIS
ASM, PRT: Creo Elements / Pro Engineer
CATIA V4/V5/V6
IAM, IPT: Inventor
NX
PARASOLID
PAR, PSM: Solid Edge
Pro/E/Creo
PRT: NXSTE, STP, STEP: Standard for Exchange of Product data
SLDASM, SLDPRT: Solidworks
VDA: VDA-FS
XCGM
When you import an assembly file, you can get its content as a plain geometry (a nonhierarchical set of entities) or map its product structure into native blocks or mechanical components.
If the assembly contains hidden parts, you can decide how to represent them in BricsCAD: import and hide, import and set visible, or just do not import.
The desired behavior can be changed in the Settings dialog:
You can also set other import options to automatically repair, stitch and simplify imported geometry. If you import a 3D model from SolidWorks, it makes sense to set an option to map Y axis into Z (because in SolidWorks the vertical axis is Y).
For SolidWorks and other native CAD formats it is possible to specify alternate search path, which will be used to look for parts absent in the imported assembly folder.
© Menhirs NV. All rights reserved. |
