bim:get-assigned-building
(bim:get-assigned-building  ename)
Returns the building name, to which the given entity is assigned to, or NIL if that entity is not assigned to a building object.
Arguments
ename  the entity to query, as normal entity or as VLA object name
Return
the building name (as string), or NIL if the entity is not assigned to a building object
Example
(bim:set-assigned-building ent "Building 1")  T
(bim:get-assigned-building ent)  "Building 1"
Remarks
see (bim:set-assigned-building)
©  Bricsys NV. All rights reserved.
