bim:set-assigned-building
(bim:set-assigned-building  ename  building)
Assigns the given entity to the specified building.
Arguments
ename  the entity to be assigned, as normal entity or as VLA object name
building  the building name (as string)
Return
T if successful, or NIL in case of an error (like, building does not exist)
Example
(bim:set-assigned-building ent "Building 1")  T
Remarks
see (bim:get-assigned-building);
the string name is case-sensitive !
©  Bricsys NV. All rights reserved.
