bim:set-roomdepartment
(bim:set-roomdepartment  roomEntity  newRoomDepartment)
Assigns a new room department "newRoomDepartment".for the BIM room specified by "roomEntity".
Arguments
roomEntity  room entity of an existing room (ename), as returned by (bim::create-room) and (bim::create-associativeroom)
newRoomDepartment  new department (string) for the room
Return
T if successful, or NIL in case of an error
Example
(bim:set-roomdepartment roomEnt1 "Left Wing")  T
(bim:set-roomdepartment roomEnt2 "Right Wing")  T
Remarks
see (bim::create-room) and (bim::create-associativeroom);
the room department string is case-sensitive !
©  Bricsys NV. All rights reserved.
