bim:set-roomdescription
(bim:set-roomdescription  roomEntity  newRoomDesc)
Assigns a new room description "newRoomDesc".for the BIM room specified by "roomEntity".
Arguments
roomEntity  room entity of an existing room (ename), as returned by (bim::create-room) and (bim::create-associativeroom)
newRoomDesc  new description (string) for the room
Return
T if successful, or NIL in case of an error
Example
(bim:set-roomdescription roomEnt1 "Room-1a at first floor")  T
(bim:set-roomdescription roomEnt2 "Room-2a at second floor")  T
Remarks
see (bim::create-room) and (bim::create-associativeroom);
the string description is case-sensitive !
©  Bricsys NV. All rights reserved.
