DEScoder - Freeware Lisp
encryption utility for BricsCAD
This software provides strong
BlowFish encryption for AutoLISP files - these encrypted AutoLISP
files can only be used and loaded by BricsCAD system.
DEScoder is mainly designed
to support AutoLISP application developers, providing a maximum
comfort for the development cycle, and to protect the application
code.
Main functional
features
- single file mode
to encrypt specified Lisp file using BlowFish
algorithm
- project mode
to create encrypted "container" file, wrapping
multiple Lisp, DCL and Text files into a single encrypted
file
(similar to AutoCAD VLX application
files)
- VLX compatible *.prv and
*.prj project files - this allows to
use the project file for BricsCAD and AutoCAD, to create *.vlx
application file for AutoCAD, and *.des application file for
BricsCAD, based on the same, identical project
definition
- LISP and DCL
compression to reduce file size,
providing faster application load
- VLX NameSpace feature is
supported (since BricsCAD version >= 18 !)
(for backward + forward compatibility,
see VLX NameSpace
Compatibility)
Main convenience
features
- drag & drop
support for all relevant dialog
controls
- command line support
for batch processing
- wildcard support
for file specification in command line
mode
- program dialog is resizeable
and persistent (size and positions are
maintained across sessions)
- singe file history
for last-used 30 Lisp source files for quick
access to most often used Lisp files
- project history
for last-used 30 projects for quick access to
most often used projects
- automatically reload
last-used project at startup, to
quickly rebuild that last-used project with a single
click
- tool tips
provide assistance for beginners, can be
disabled
DEScoder Single-File
mode
DEScoder Project mode
For a detailed description,
please see full documentation :
