VLX NameSpace Compatibility
Since DEScoder.exe v2.7
The "VLX NameSpace" feature to isolate Lisp
code running in an own "NameSpace" (prevents clashes of same-named
functions, between different Lisp files).is available since
DEScoder v2.7, and supported since BricsCAD V18.2.
But the internal DES data format and options
storage has been made backward + forward compatible, to provide
best level of compatibility possible.
The following table shows the relations between DEScoder versions and BricsCAD versions :
Lisp files encrypted by |
works in BricsCAD V11 - V18.1 |
works in BricsCAD >= V18.2 |
DEScoder <= V2.6 no NameSpace support |
Yes |
Yes |
DEScoder >= V2.7 NameSpace feature
disabled |
Yes Partially (no NameSpaces available !) |
Yes Yes |
© Bricsys NV. All rights reserved. |
