IAcSmEnumProjectPointLocation
The Enumerator for IAcSmProjectPointLocation objects.
available methods :
(setq cad (vlax-get-acad-object))
(setq ssmgr (vla-GetInterfaceObject cad "BricscadSm.AcSmSheetSetMgr"))
(setq smdb (vlax-invoke-method ssmgr 'OpenDatabase dstfile))
(setq iter (vlax-invoke-method smdb 'GetEnumerator))
(setq ppLocations (scanUntilObject iter "AcSmProjectPointLocations"))
(setq iter (vlax-invoke-method ppLocations 'GetEnumerator))
Note : "(scanUntilObject)" is a utility function contained in the sample Lisp files in folder "<LDSP>/SheetSetManager-Lisp-API/LISP Sample Code"
Next
iterates to the next and returns the actual element
(while obj  (setq obj  (vlax-invoke-method iter 'Next)))
HRESULT Next ([out, retval] IAcSmProjectPointLocation** location)
Reset
resets the enumerator to the first element
(vlax-invoke-method iter 'Reset)
HRESULT Reset ()
©  Bricsys NV. All rights reserved.
